shortsguy1
I have been slowly changing out all the fluids in a 1966 3000 BJ8, but am stuck with changing the transmission (aka gearbox) fluid. I honestly don't know where the fill location is. The Mk III Driver's Handbook says it is "situated in front of the gear lever" under "the inspection panel in the top left-hand side of the gearbox cover." Kenneth Ball's Austin Healey Owners Workshop Manual says "the dipstick is combined with a filler plug located on the righthand side of the gearbox cover." Perhaps the left hand vs right hand issue relates to whether the car is left or right hand drive (mine is left hand drive). Even if I know which side of the gearbox cover (aka transmission tunnel) it is located on, I still don't fundamentally understand how I get to the inspection panel.
According to the Workshop Manual, I will have to pull up some carpet (they call it a floor mat) for this job. Does anyone know how this carpet is normally attached (glue, screws, gravity, chewing gum???). I don't have access to the car right now, and try to figure out all the details in advance. I will have access to the car for a few days over Thanksgiving, if the carpet is easy to remove, I should have time to take care of this. Sorry if this is a dumb question.
