I bought my first TR6 in 88. It had point wobble. i.e. the bearings and lobe faces were worn. At that time no one rebuilt the distributors. A new distributor was beaucoup bucks. More than I wanted to spend on a driver.
So I installed the Allison(now Crane) optical pickup ignition, later added to it with an MSD amplifier.
It is great. Good strong ignition, ALWAYS. Must use a good rotor and cap. Bosch caps and rotors don't last with Crane and MSD, not nearly as long as Accel or Lucas.
Never have to worry about wear on the distributor as the optical pickup compensates for it. Now if the bearing finally goes bye-bye and I can take the top of the shaft and knock it side to side and touch something, then I know it's time for a rebuild. Now that Advanced is in business, I may get around to having him rebuild it some year. He might also be a good source as, I understand, he builds the distributor with whatever primary ignition you want; points, condensor, petronix, allison. etc.
