First off, let me apologize if this is in the wrong forum. I am new here. I am working on a 1977 MGB. Overall, a very solid car. While driving down the road the other night smoke started pouring out from behind the steering wheel. Making a hasty exit to a safe parking spot, I shut everything down. The smoke subsided. I re-started the car and all seemed ok except the headlights were not working. I managed to get home without headlights. When I took the covers off behind the steering wheel I found the red wire with green tracer melted. The blue and brown wires were OK. I dis-assembled the headlight switch and it does not appear that there was a problem with it. When I put a jumper between the R/G wire and the brown wire, all gauge lights and running lights come on w/out anything heating up. Jumping the R/G wire and blue wire, nothing happens. I suspect this is the headlight circuit. This car has halogen light bulbs and what I think are two headlight relays mounted on the left side inner fender. I cannot find any blown fuses in the fusebox mounted on the fender well. Having said all that, I am wondering what caused that to happen, and where do I begin to look for the problem?
