SteveBones
I have "new" electrical issue with my 1958 TR3A. When I turn the key, nothing happens. What I mean is that the red generator warning light is dark, the fuel gauge stays at empty, and the amp meter does not move. The horn does work. This happened after driving the car for 20 minutes with no issue. A few minutes after shutting off the car, and turning the ignition key to the on position, nothing happened. I just started trying to track down the problem. So far I have done the following:
1) Checked the battery connections. The ground wire was loose at the terminal. I tightened and no change.
2) Fuses. These are the original type fuses. I removed and cleaned the fuse connection ends. No change.
3) I plan to use a voltage meter with the resistance setting to determine is the ignition switch is working correctly.
4) I will take a look at the wiring diagram and start working from the ignition switch to see if there is a bad connection.
Based on what I describe, is there any recommendations on what else to do to isolate this electrical issue?
Thanks,
Thanks,
