well friends, I am hoping someone is a contractor - or at least has some electrical knowledge. I am doing some work in the apartment attached to our house. This necessitates moving a sub breaker box. There are large (8 gauge?) wires running from the main panel to this panel (in a metal casing). It is 220 volts. The easiest way to move this would be to disconnect the wires, put in a junction and add about 10 feet of wire through the attic to the new location. Then I don't have to wrestle the casing - most of which is under the floor anyway.
That said, I have never joined wire that thick before and can't imagine it would simply be wire nuts/Marettes. Any thoughts?
thanks all!
thanks all!
