item number 27 here https://www.victoriabritish.com/icatalog/sm/0118.aspits kinda a square flimsy plastic retaining clip, if your careful you may be able to save it. Its one of those things that once you see it you understand it.....then they are simple, the problem is is seeing it....
You were right on the button there! After I ripped the old one out with my trusty needle nosers I found the retaining clip.
Fortunately I had not damaged it.
Got it all installed. Seems I guessed the right wiring patter first time. Down one click I get parking lights. All the way down & I get all the lights. This is fabulous!
