T
TRDejaVu
I have the rear brake cylinders apart. They are both Girling but with different idents, so I presume that one was replaced previously. My manual shows that the Girling doesn't have a spring behind the piston whereas the earlier Lockheed does. However, one cylinder had a spring and the other didn't. I don't know if the spring is a correct modification, or a mistake. Can anyone shed any light on this.
Thanks.
Thanks.
Hi Guest!
