My 57 2 port bn4 block is going to the hot tank tomorrow and I can't get the dipstick tube out. I know the later ones are threaded but I can't see any threads on mine. If I twist any harder I'm going to ruin it. I've tried head and penetrating oil. No luck. Help!
Thank you SOOOO much Randy! As the sun was setting last night I was certain it was brass colored but in the bright morning I think I may have been just seeing surface rust. When I scratch other parts it does indeed look steel. Time to clean it up!
It never even occurred to me to check if it was steel or not. I was absolutely convinced it was some softer metal before I even began. Sometimes I need to remember to step back and look at the big picture...
Thanks again Randy. Your advice on several of my questions has been invaluable.
