Early [11/73] 1974 Radiator Removal -
AngliaGT
Just who was the genius that made it so difficult to remove it?Does anyone have pictures to help me get it out?This is a 1275. - Doug
The entire shroud must come out. Step one is to remove the grill. Then there are 4 bolts and two screws to remove to lift the shroud/radiator out.
I got the screws loose,but can't get them free.The two upper bolts that hold the shroud in are missing.Are the other two directly below them? - Doug
Also - where's the best place to get hoses for this? - Doug
IIRC the bottom two are access from below the front valence.
