davidtinker
Member
Just got my E Type running smoothly after many months of rough running and misfires. Having replaced almost everything on the ignition circuit, and retuned the carbs more than 6 times I finally gave up and took it to a garage to be placed on the analyzer.
The results were that the engineer thought he could hear a HT leakage but the analyzer was showing normal and so too showing normal on the timing and fuel mixture. The car came away running a little better with the advice being to change the HT leads and the Distributer Cap.
Then found out that Dist Caps with screw terminals are no longer available ( unless you know better ) so fitted S2 Cap and Lead set. I am pleased to report an Instant improvement and I am now confident that I can go for a run, stop for fuel at a service station, and restart the engine!!
David Tinker. Wales UK
