richberman
Ok folks. I need some hints/help.
I've got my e-brake handle attached to the cable. From end of cable is attached at bracket, then again with mid-cable bracket. I've also got the rear connector attached to the bracket but can't get the lever pulled over enough to drop in the clevis pin. Do I need to remove the springs or is there another trick I'm missing?
thanks,
rich
thanks,
rich
Hi Guest!
