Hi all,
I am having a hard time starting my TR3A cold first first time
in the morning. After I get it started with the help of starting fluid, it starts up fine for the rest of the day.
Is there a specific dwell angle that I should be seeing at 800 rpm. I see about 49 degrees right now. I have a combination dwell/tach and have never really understood what the dwell represented. Some research on the net seems to indicate that it could indicate the points gap which I have measured and is as close to the .016 inches as I can make it. I read more than once that looking at the dwell on an older distributor can also be a waste of time but if it helps me to verify the gap I have set I am all for it.
Another thing I am wondering about is if it is possible to set the advance too far when the engine is warmed up. Making it harder to start when dead cold. Does more advance
equal harder to start cold?
Thanks very much,
Jim Lee
Thanks very much,
Jim Lee
