Dumb Late Night Question
tony barnhill
Great Pumpkin - R.I.P
Okay - the wiring diagram for my '63 MkI Midget shows "SW" & "CB" as the terminals on the coil - but my old & new coils only have "+" & "-".....its late on Friday night...I'm tired & angry...which is which?
Is "SW" "+" or "-"?
The ignition switch lead should go to the SW post of the coil, which if it is a negative ground car will be +. The CB is to the contact breakers in the distributor or - in todays terminology.
Now hopefully, you've already gone to bed and you will install the wiring to the coil in the morning after a good night's sleep.
Aloha(It's only 20 to 7 here in paradise).
On a '63 it came as positive earth, so SW would be a minus sign on that setup. If the polarity is reversed then Ron's setup would apply.
Just some pot stirring... :devilgrin:
In reality it makes no difference. It will run just fine either way.
We've had this discussion before, and I agree that it will run either way. However, I suspect it works better if it is wired according to the markings.
they do indeed run if bacwards and run BETTER if the polarity is correct.. you only get about 1/2 the voltage if its backward... have a look at a wiring diagram and you'll see why this is so...
OK...."SW" = "-"...that's the weay I'll hook it up (if I ever get the correct wiring harness!)
My point was not to panic, both will work just fine.
Understood, Jack - I just wanted to 'get it right'....plus, I was real tired last night!
