martx-5
Well, I finally got the dual master brake cylinder mocked up for the TR3 resto. Revington gets a ton of money (about $1400 at current exchange rates) for their system. You also have to use a TR4 pedal assembly, and you have to widen the hole in the firewall to accept the three master cylinder assembly. After playing around with this for about a month, I discovered that I didn't need to widen the firewall aperture if I used three Girling remote reservoir masters. I also noticed that is was possible to use the original TR3 pedal assembly (the TR4 assembly has the connectors to the master's wider apart). One of the big problems was the wiper motor. It is right next to the master cylinder box. I didn't want to move anything, and I didn't want to do anything that wasn't easily reversible back to original.
After several master box mock-ups with the help of Tony at RATCO it looks like I've got a go situation. It's possible to use the original TR3 tin can reservoir. I've got them set up for the front and rear master's...but, I've got to get rid of that hose clamp. I need to use someting more like the original on there. The plastic third clutch reservoir...well, maybe I should just go to three plastic reservoirs.
Anyway, I'd like comments...good and bad. This could also be done alot easier on the TR4. I'll probably be mocking up a system for that with Tony in the near future.
