ronzet
LBC Fans,
A little while ago I posted a query about the Flamethrower distributor and many had responded with a suggestion to contact Advanced Distributor to rebuild my original. I have yet to send the Dizzy so decided to rebuild it myself this weekend....
New points, condenser, rotor and cap, new coil, lubed the advance plate and checked for correct movement under vacuum, checked all the wiring inside and outside the Dizzy fixing anything that even remotely looked suspicious.... Put is all back together and the car ran PURRfectly... started on the first turn, idled smoothly.... Sooooo
Took it out this weekend for a drive through the hills... ran GREAT.... Drove it around on Sunday and Monday, to the store, around town, waving happily to all ... NO problems...
Went to pull it into the garage last night..... crank, crank, crank.... no spark yet again!!!
Before pouring gas all over it and throwing a match to it...
Can anyone suggest A N Y T H I N G?!?!?!?
