OK, I've the passenger side fender /ubbthreads/images/graemlins/confused.gifoff, thanks those who helped. Now the driver's side fender. I've taken off the bolts at the front. I've taken off 3 bolts from the kick in the interior. I took off the bolt under the top back of the fender itself. As I pull away the fender there is one more bolt. It looks to be about 1/2 way up the flange on the back of the fender (By back I mean towards the rear of the car) It looks as though it is about 6-8 incehes higher than the bolt I pulled next to the clutch pedal. However, I can't find the head of the bolt. Where is it?
Thanks in advance for your help. I truly appreciate this board.
JP
JP
