BlueHealey1951
Member
Hi Guys, I have a 67 BJ8. It is 1 year out of restoration, one last bug to fix. A significant vibration develops around 60 mph. It is too fast a vibration to be from the wheels. Pushing in the clutch while at speed does not change the vibration, so it is not the engine. I have replaced the transmission. I have also replaced the drive shaft that has been balanced many times from different shops. I have checked the drive line angles. Removed the bolts from the pan hard rods ( thought they might be rotating the axle). I have placed various shims on the axle mounts to rotate the axle. Changing the pinion angle only makes things worse. The only thing left is the rear pinion/axle assembly. Any ideas on how to check for a worn pinion bearing? The front seal on the pinion has a slight leak.:dejection: Steve
There have been several suggestions about balancing brake drums. The vibration is much faster than a wheel speed vibration. Plus there is a change in the vibration when I'm accelerating or decelerating.
