Patton
It is a beautiful Spring day here in SW Houston with a clear, dry day in the mid 70's!!!
I was planning on working on the Healey today to get it ready to take it to the Spring Tune-Up hosted by the Gulf Coast Healey Club.
I haven't run the car in about a month, so I was going to let it warm up a while in the garage (opened) to let the car warm up before I drove and let the battery charge up. It started without a problem, and I left it runnning while I was working nearby.
After about 15 minutes, I looked and the water temp was at 190 degrees and running fine, so I went to move my wifes car out of the drive. As I was walking up to the Healey, I saw the exhaust puff a little grey exhaust smoke and the car stopped.
I got in the car and after a couple of turns, the car started up. I backed the car out of the garage, turned it around in the driveway, headed toward the street, and it died again. I smelled a little gas, so I thought that the car flooded, so I waited a while and tried it again. The car kept acting like it was about to start but wouldn't.
Finally it started again, but not smoothly. I looked at the exhaust and it had grey smoke out of one exhaust for a few seconds, but not the other. I decide to get the car back in the garage, but it died after moving a couple of feet.
By this time, I had spent a lot of time turning the car over so I put the charger on the car and left it for an hour.
I came back out and tried starting it again, but no luck. I got my neghbor and his kids to help me push it into the garage.
I am pretty sure that the car is getting fuel as the fuel pump is not constantlly clicking, and when I took the sparkplugs out, they were wet (presumably from turning over).
While I had the plugs out, I checked the pressure. I put my tester in #1 and the pressure was 150 like the last time I checked it. As I was taking the tester out, the bottom part that goes into the head came unscrewed at the base of the hose. I had to go get a 11/16 socket and get it out.
Once the base was out I screwed the parts back together and tested #2. It came out at 130! OK, I start to worry. I test #3 and get almost the same, then #4, #5, and #6 all between 130 and 140.
I start wondering what happened, then I thought that when the tester came apart, something may have changed with the tester. I rechecked #1 and it was down with the rest of them. I guess that something about the gauge did change. It is a relief that the pressures came up in range.
Now I still have to figure out what is going on with the car and why it died.
Patton
Patton
