sparkydave
How much dragging is normal? I took the wheels off to see if I could figure out why the brakes have been squealing. I overhauled the brakes a few years ago; new pads, new anti-squeal shims since it was missing two of them, new master cylinder, cleaned up the front calipers, and ended up replacing the rear wheel cylinders about 2 years ago. The brakes work fine, but when I was checking them out this evening I found the discs drag a bit. I squeezed each side back a little, and the pistons move fine, but when I pumped the brake to seat them the disc still drags noticeably. Anyway, the discs get pretty toasty after a short drive, and I'm guessing since they are hot they are squealing. So, any ideas on why the brakes might be dragging?
