DOS printer!
NutmegCT
Bronze
Gentlemen -
One of our library volunteers uses an old DOS database app (PerfectFiler). I've got it running in a DOS window, under Windows XP. The volunteer prefers (!) that she keep using this DOS app.
The app outputs to an old Panasonic KX-P2023 dot matrix; in the DOS window, the app prints without problem to the Panasonic.
As the old dot matrix printer isn't going to last forever, and eventually will have mechanical problems ...
... is there a way to capture the DOS (LPT1) output from PerfectFiler, so it prints to a printer on our Windows network?
I've found several "DOS to network printer" apps which run under Netware or other network systems, but none specifically to capture DOS output and send to simple ol' Windows networking (the networked printer). The Win based apps on her computer output to the network printer fine. Of course, taking PerfectFiler's Panasonic driver output and getting it into the HP OfficeJet 7500 driver is a related issue.
Thanks.
Tom
Just curious, is this PefectFiler authored with FoxPro by chance?
Glad you asked. I went back and looked and realized it's actually PFS:professionalFile, from the late 1980s.
That's what happens when I take a 30 year nap.
T.
kellysguy said:
Why not just replace the volunteer with a newer model? :jester:
She's the biggest donor!
T.
Systems Analysts are a cagey bunch, Dave.
Just check out BOFH. :wink:
Das Boat
Dos Printer
So are you saying Don that the printer gets a grade of below C-level?
Thanks Greg. Never even thought of that.
If I can get the DOS app to print to a file, how would I get that file directly to the Windows printer?
Tom
Thanks Greg! The printer is a stand-alone HP7500 with a built-in printserver. Will be interesting to try to find the "name" of the printserver, to follow that MS idea.
Also, I found "PrintFil" , which resides in memory on the Windows machine, and automatically re-routes LPT output to a designated printer (local or network). Actually finds the printers in the Windows machine's Printer Control Panel, and lets you choose which one for the DOS LPT output. Pretty cool.
Tom
