Barryp
I'm in the process of trial fitting body panels back on my BN4. I've fabricated a door gap adjuster tool similiar to the one Randy Forbes has shown here but not nearly as exotic. Dummy engine with head and gearbox are in the car with about 50lbs of ballast in the trunk sitting on wheels at target ride height. Plan to weld the the new right side rocker panel in place once all gaps a are set, currently attached with sheet metal screws. Left side gaps look good, right side door over laps the rear fender slightly at the top.
I can make the right side gap correct with the adjuster. My question is how do you hold the correct measurement once the adjuster tool is removed?
Barry
Barry
