MGB Door card replacement
Celtic 77
Am contemplating replacing the door cards on my 77 B. Plastic clips, or chrome screws and washers? In a way i am leaning towards the screw and washer. I assume they fit in the same holes as the plastic pieces.
Thanks
MKI were screw and washer. Yours are metal clip into plastic plugs.
I would use screws. Be careful removing the plastic around the inner door handle.
Thanks for the info... I kind of like the look of the screws. A little more vintage. I assume the holes for the screws are existing or self-tapping?
Just plain screws with trim washers.
I would not use self tappers. You might want to pull the plastic inserts out of the door to help the door card sit flat.
