jhorton3
I need to adjust the bottom right corner of both doors where they're close to the b post. This corner for some reason is too far in toward the cockpit, which leaves a ledge at the sill. How do I adjust this so it's smooth with the rest of the bodywork? The other corners seem to be lining up OK. I didn't know if this is something I can adjust at the hinges, or if I need to get a 2X4 and apply some slight pressure to get it to sit flush. By the way, the weatherstripping has yet to be installed for either door opening.
