timbn2
I'm using a 12v/25 amp rectifier similar to the one sold by Caswell. I have 6 pieces of rebar around a 5 gal bucket all wired together with copper wire. i have the red lead on that and the black lead on the part... or more precisely to copper wire wrapped around the part. I used 1/2-1/3 cup arm and hammer WASHING soda in water as the electrolyte fluid.
i tried 2 different small parts (brake master cylinder) and a 1/2" rod ranging form 15 min to 2 hours on 8-12 volts. the most amps i ever got at the highest volt setting was 5. Does that sound right, or should i be getting more amperage at 12 volts?
also regardless of the time, there didn't seem to be a whole lot of rust removed on either part. the water definatly had rust in it and so did the re-bar and the part was "bubbling" like its supposed to.
The master cyl. only had a very small amount of rust on it and it still had some on it after about 1 hr.
Did i do anything wrong? Do i just need to leave my parts for more time? I am also told that as soon as the part is de-rusted the reaction will stop despite current flow. is this true?
thanks a lot!
thanks a lot!
