TR4/4A Does a 4 wood dash fascia fit a 4A?
JimTR4
I know there's no rheostat hole on the 4A but would a 4 dash fit a 4A?
Thanks in advance.
Jim,
Knowing you will have an extra hole in the dash - everything else should fit.
Actually, the fit will be a little off - the difference will be in the switch plinth area. For a TR4, the cut into the dash is a little deeper, for the 4A the cut is much shallower and I think a little wider.
There is a seller on ebay who shows them as interchangeable - but with that difference on the bottom they are not the same.
