do 100-6 rear fenders unbolt ?
beaulieu
Hi
quick question,
do the rear fenders unbolt ?
are they the same as the AH 3000 ?
I figure they do , but never had a body stripped down so I am not sure...
Anyone have a photo of a stripped body ?
Thanks
Beaulieu
Yes they unbolt, fasteners are located behind the shutface panels,under the inner wheel arch and inside the boot. If you have a factory type manual you can see the methods used there.Also Moss Parts catalog will give you some insight to the assembly.--Fwiw--Keoke
[ QUOTE ]
Hi
quick question,
Thanks
Beaulieu
[/ QUOTE ]
on cue...
It doesn't get more stripped (of bolt-on parts) than this!
thanks for the chassis picture , it shows what I need to know,
does the front windshield cowl unbolt ?
what about the rear one between the back seat and rear hood ?
Beaulieu
[ QUOTE ]
Beaulieu
[/ QUOTE ]
What you see in the previously posted picture is a one-piece assembly; there is not a single part left that can be un-bolted.
