DM6 disrtibutor???
BOBBYR
Hi Guys,
Under the rotor,in this distributor, is there suppose to be a felt disk to hold oil for the points? Years ago, in certain distributors, I remember seeing them from time to time.As always, I appreciate your help.
Bobby R
BOBBYR said:
Hi Guys,
Under the rotor,in this distributor, is there suppose to be a felt disk to hold oil for the points? :nonod:Years ago, in certain distributors, I remember seeing them from time to time.As always, I appreciate your help.
Bobby R The only small felt disk I know of is located in the center of the Dizzy cam shaft and becomes visible when the rotor is removed. This disk [should always be there ] is used to hold and supply lubricating oil to the Shaft that supports the cam. P.S. Points do not like oil---Fwiw--Keoke- :laugh:
Hey Keoke,
How's everything by you? I'm sorry I didn't explain this better.The felt you're explaining is the one I remember but when I look under this rotor, there is no felt disk.(just a phillips head screw) Do you think I should make a felt disk for this? Thanks for your help.
Bobby R
BOBBYR said:
Hey Keoke,
How's everything by you? I'm sorry I didn't explain this better.The felt you're explaining is the one I remember but when I look under this rotor, there is no felt disk.(just a phillips head screw) Do you think I should make a felt disk for this?--- :yesnod: :yesnod: :yesnod: Thanks for your help.-OK En when you get it installed put about 3 drops of engine oil on it too.
Bobby R
