jlaird
Am I correct in that for setting the dizzy, the #1 piston would be all the way up and the #4 all the way down with the timeing mark on the dampner at 7 degrees? Now the roter should point at the front wire, about at the #1 plug in fact?
The reason, of course, that I ask is that engine is out and I wish to make sure it is not 180 out. Do I remember correctly or am I all wet?
Associated question and what brings this up is that puts the vacuem advance on the Dizzy at a strange angle unless and maybe I dis remember, there was a rubber angle peice attached to the Dizzy vacuem fitting that corrects for that strange placement? LOL and it is Moss # 153-840 however your commens per the above might let me sleep better. /ubbthreads/images/graemlins/hammer.gif
Strange how setting here typing this helps to work it out in my mind, all kinds of Bugeye trivia come from someplace but I am never quite sure if I have it correct or not till you guys set me straight.
