G
How critical is the gasket thickness between the distributor housing and the engine block. "The Book" seems to go into great detail about measuring the thickness of the gasket with a formula for setting the dizzy in place. The original builder of my engine just layed a smear of silicon down on the mating surface and cranked it down. I, in all my wisdom, hate straight silicon-smear-gaskets and decided that I needed a real gasket, with appropriate sealant. In doing this I am sure that I have backed the drive dog and gear out the thickness of said gasket. Seems to turn ok. Is lash setting here of such a great importance in engaging this spiral gear? There ain't a lot of room between the studs coming out of the engine and the pinch plate holding my dizzy in check. Trifles make perfection but perfection is no trifle. My OCD saying for the day.
Bill
Bill
