guzzul
Good point Doug. It didn't occur to me that the centrifugal mechanisms should indeed be balanced. I wonder in practice whether they stay that way over time, or if spring tensions, friction and dirt play their part in creating some imbalances.dklawson said:One of the beauties of electronic ignition is that there is no side load on the rotating parts and therefore the mechanical bits are supposed to last much longer.
Maybe the electronic dizzys do, in fact, last longer than the mechanical points models. I don't know. The fact is that the electronic dizzys do wear. I replaced mine in the Spit last year for this very reason (i.e. wobbly dizzy). I had quite a bit of play in the shaft, to the point where I could physically close the pickup gap by moving the shaft.
So back to your question of what causes the wear? Again, I'm just assuming that if you spin a shaft in a bushing for long enough it will wear on the bushing, lubrication notwithstanding. There has to be some dirt in that oil causing wear. I would think too that over time the advance mechanisms will not work perfectly.
