christophe
I finally managed to get our 3000 up and running the other day, but not for long. I noticed a noise that sounded like a bad bearing on the first couple of cranks, but I thought it was just the starter gear since it would do it sometimes when cranking, but not others. Once the car started I no longer heard it the noise. The car ran for about 15-20 seconds sounding the best it ever has, then it suddenly cut out. I thought the ignition system was at fault, but it turns out that the housing(picture below) that the distributor connects to, which has yet another shaft and drive gear, was the problem. I pulled it off today and found that the shear pin was broken. The shaft inside of the housing is frozen and will not turn. I tried to drive it out, but could only get it to the base of the housing and will need to take it to someone with a press.
Anyway, what would cause that shaft to freeze up. It was getting oil, so I am at a bit of a loss.
