Well, if the engine will not turn over, then the distributor is not involved. Look elsewhere. Turn on headlamps and move key to 'start' position. If the lamps dim considerably, then you're drawing big amperage at the starter, so look at battery, cables, siezed engine and so on. If they do not dim, then there is a problem in the switch or related areas before the starter.
