Bruce_B
I'm still working on my wiring,but the starter works and the ignition switch is wired up. Car is a 59 BE with a 1275 engine, positive ground.
What's the minimum "juice" that I need to start the engine?
I'm thinking that if the coil is hot, the distributor is attached to the coil and the starter motor is good to do that should be enough. I'll worry about the generator later on. I just want to start up the rebuilt engine.
Ideas?
Thanks....
Ideas?
Thanks....
