G
I'm in the process of converting to a high pressure fuel system (for fuel injection). Almost done. Had to change the fittings on my fuel tank so I had JIC (Steel) fittings welded on to the tank. I'm using ss braided hose and want to use anodized aluminum AN fittngs to connect to the tank. But I'm wondering if I'll have a corrosion problem. From the brief research I just did on the i'net I'm thinking I won't have much of a problem. Seems that part of the equation is the presence of a conductive agent - such as water - and seems that gasoline isn't a great conductor. And the connections will be in a dry location. So I should be in good shape, correct?
