I am currently trying to dismantle the brake master cylinder on my 1970... (I know that master cylinders have been talked about recently, but I did not want to hijack anyones thread!) I can only get as far as removing the outer spring under the boot, and then remove the lock ring inside. There is that nylon washer/seal that I cannot get to move... any ideas? Also, does anyone know what type of wrench to use to remove the reservoir from the master cylinder - I cannot find one that fits inside the recessed areas!
I hope this make sense...
Thanks in advance!
Soup!
Thanks in advance!
Soup!
