rlich8
I have some oil spewing out of my dipstick, and I can't seem to get it to stop. I made sure the "spring" on the stick that holds it in is tight, and it is. Is there something more than a felt seal?
This leads me to believe that perhaps my crankcase is under too much pressure. Should I be checking the PCV valve? The oil caps on the 4A are NOT vented, correct?
I also have a leak that appears to be at the bottom of the fuel pump, I just installed a new gasket. Any ideas on that?? All help is much appreciated!!!
Thank you!
Thank you!
