bob hughes
OK all you BJ7 owners, and possibly BJ8 as well.
Before I started the rebuild of the engine, 12 imperial pints filled up the engine to the full mark on the dip stick.
Sent the block off for a re-bore and fitted a Dennis Welch ali sump when it came back- nice.
Put 8 imperial pints of oil in and blow me down it came up to the mark on the dip stick, discussed it with Bill Rawles - AH specialist over here, and I asked if the sump could be a bit smaller in size than the old pressed metal one, he said that if anything the DW sump should hold more oil, and you can put in up to 14 - 18 pints as the racers do and I should just top it up to 12 pints and remark the stick. OK I can do that but I am interested in finding out what has happened.
The block was sent away with the dip stick tube still in place - could they have removed it and replaced it with an incorrect tube? I'll make that phone call.
How much tube should be protruding from the block? The dip stick is the same as it has always been in my possession.
Comments welcome please, and keep 'em clean lol
Bob
Bob
Hi Guest!
