Dimension Needed
big6
I am fitting the front shroud on my BJ7. I need to determine if the shroud front lower radius has been flattened due to impacts from curb stops or if the upper cross brace is too low. The sections of the lower front of the shroud that attach to the frame are missing and will weld the missing sections and work the aluminum to fit if I have the correct distance from the top of the cross brace upper panel.
Can someone provide the distance from the top of the frame rail to the top of the cross brace upper panel? The dimensions from both left and right sides will be helpful.
Thanks in advance.
