bobmga62
Hi.. right hand front headlamp is real dim, compared to the left.
bought a new bulb and installed, but problem is still there..
Must be wiring.. I thought if it was a ground problem, it would be either on or off, not dim.. but before I go chasing everything, should I start with the ground..
footnote: if you are like me, you probably have everything in duplicate, cause you buy the part first, then find its always an opposite problem..
thanks for the help
Bob
thanks for the help
Bob
