Differential seal leak
BoyRacer
OK, I confess I'm getting lazy, but I would like to change a diff seal in a 3000 without taking everything apart. Is it possible to get the old seal out with the pinion shaft still in place?
If you mean the pinion seal, yep. Break the driveline at the rear yoke and undo the big nut holding the yoke on (you'll need a BIG wrench, and maybe someone standing on the brakes in addition to the e-brake being set to keep the diff from turning). Pull the yoke off and pull the old seal with a seal puller or suitable improvised tool (screwdriver). Push the new seal in, making sure the outer edge of the seal aligns with the inner edge of the slight bevel on the inside of the the third member where the yoke goes (so the new seal rides on the smooth machined purpose of the yoke). Replace the yoke and torque the nut to 140ft-lbs.
Good idea to paint mark the nut and shaft then torque the nutup first to ensure that you won't be resetting it to a completely different torque than it is presently. Ideally your paint mark and 140lbft will occur at the same position upon re-installation. If there is a significant difference in where the nut ends up it could mean problems later on.
