Westfield_XI
After a very long struggle with persistent overheating, (turned out to be a head gasket) I am finally able to put some miles on my Spridget powered Lotus replica. Now it sounds like I have a problem with my diff. It howls on overrun, but not under load. This diff is a "bitza" made up of my '67 donor axle with an eBay 4.22 gearset. The problem is that I didn't think to check the gears for correct shimming, I just bolted it up and put it into the car. That was only 650 miles ago so I hope that I have not done permanent damage.
Any tips on where to look for instructions on setting up a diff? Or a good shop in Los Angeles that could do it for me?
Hi Guest!
