T
Tinster
Don't wish to steal someone else's similar thread.
Poolboy/Paul:
I downloaded the vacuum article thanks.
Data:
My valves are set at a not-tight .010", timing is 12* advance,
points at .015", carbs are close but not finally dialed in.
Warm idle was 1100 to 1200 rpm when I took the last vac. test.
I get a very constant, non-twitchy 21 in-Hg at this idle.
Punch the throttle shaft and I get a fast drop to zero
followed by and equally fast surge to 25 in-Hg and then back
to a constant, non-twitchy 21 in-Hg.
Today: 1/2 Hr drive to warm engine. Car ran very well. While hot,
adjusted carbs to a nice 900 rpm. Timing was at 10* advance,
vacuum at 21 in-hg w/ steady needle. Vacuum maxed out at
22 in-Hg.
With dizzy and vac pipes plugged; I was able to get vacuum
down to 19 in-Hg before engine stalled. At 20 in-Hg the engine
was somewhat smooth running but my timing was deep into
negative-below zero on my gun and my idle rpm were bouncing
around 400 to 500. My timing wheel is not original. It has
one slot full across and one 1/2 slot across the width.
So, wuz up with my engine?
Thanks as always,
dale
PS: If I time by ear and then test- I end up with 10-12* advance, 1000 rpm idle and 21 in-Hg.
Poolboy/Paul:
Data:
22 in-Hg.
Thanks as always,
dale
