TR4/4A Difference between two Oval Air Filters
morris ocho
My non-scientific gut feeling is that the perforated outer paper doesn't restrict airflow enough to make a difference on a street car, but I also don't see much point to it -- it might keep a huge bug from getting stuck between the pleats maybe? But it won't improve filtering ability.
K&N published a math formula that was useful for calculating what size filter would give sufficient airflow for given engine size and RPM. Based on that formula I calculated that the single round 3" x 6" OD filter on my 4.5L 6-cylinder was about 3 times the size it needed to be. That's the reason I wouldn't be too concerned about the outer paper on those.
I wonder if that paper is a protective layer that's meant to be removed before use?
Protects the pleats from accidental damage as they are pretty fragile . Just be happy you dont have
to knit your own. The tr4 a filter had a metal wrap with similar holes.
Mad dog
