M
Member 10617
Does anyone have any experience with diaelectric grease? This is a mystery substance to me... A mystery substance because half of what I read about it is contradicted by the other half of what I read about it.
It is recommended for protecting electrical connections from corrosion, and there is a YouTube video showing someone applying it to connectors. They say that it will enhance the electrical connection because it prevents corrosion and keeps out water and air.
But, it is an insulator and does not conduct electricity. Those who point this out say that it will interfere with the electrical connection and may even prevent it altogether.
So who is right?
I'm thinking that it might be ok to apply it over an electrical connection (like the screw holding the battery ground to the car) to keep out moisture, but not between the connector itself and the metal of the car. There, I would think you'd want to have metal to metal.
So who is right?
