Re: Died maybe some brain damage !?
Well, the car still runs but still weird turn signal stuff-- plus something I noticed before but didn't mention about the original incident. When the turn signals stopped working, the gas gauge also went weird, showing full when the tank was half. When I turn off the turn signals the gauge eventually goes back to half.
I thought I had the problems solved but it was too soon. I had checked all around the battery circuits and for loose wires, grounds, pulled out the center dash panel and checked all wires/connectors-- wiggled and pressed things and tightened things that seemed less than secure. Car started and ran fine but no turn signal. So I pulled out my little test light and turned on the turn signal and ignition. Nothing happened initially but just before I touched the first connection on the flasher with my test probe, the turn signals started working. About 10-15 seconds lapsed between turning on the ignition and the turn signals starting to work. I wiggled and pulled everything I could find and it continued to work without hesitation. Could also see nothing connecting abnormally with the fuel gauge.
Before going on the road, I continued to look for the other problem that caused the car to die completely. What I found was a smaller loose ground on the driver's side block, down near the starter/radiator hose area. Dunno if that could have been the cause when the main ground was quite clean and secure. So I took it for a ride around the block-- no problem. The next morning wife and I headed for the little farmers' market about 3 miles away. About 2 miles out, the turn signals went dead and the fuel gauge went full again. Later at home, pulled center panel-- nothing there; test light showed nothing at flasher. Could see nothing wrong in wires to and from turn signals and flasher. Problem the flasher? Turn signal switch? What's up with the fuel gauge?
I'm getting confused.(Sorry, Mr Lucas, wherever you are, if I made jokes).
I'd rather be driving it this summer but Geo, I think your idea of a new harness is looking more like the necessary route.
