Croaked is right. This forum does not seem to have a "delete" button when they don't work. I had photos, but too small here (even tho fine on my box) and won't blow up, so, "didn't work".
I saw that and thought it was hilarious.
Inversely proportional to the guy who had ride-on trains in his property in Oregon, and they shut him down as the bridges went over "protected" streams....
If you grab your calculator and add up the fees, it is quite a bit...especially the $750 exit survey (mandatory)!
When you upload an image and get the thumb nail, double click the thumbnail and it should give you a popup that allows you to select different sizes (e.g., Large). If it does worn when you first upload, just save the post with the thumbnails, then edit the post and try double click on the thumbnail images.
