did I get the right stuff?
JPSmit
I am hoping to finish my caliper rebuild tonight. I was just at Canadian Tire & bought Permatex Ultra Disc Brake Caliper Lube. Is this the right stuff? I plan to use silicon brake fluid (for paint safety reasons)
I also bought Permatex Blue threadlocker. Is this right?
The general consenus seems to be
Don't use permanent threadlocker (at least for normal applications - ie. not racing)
Use anti-seize where dissimilar metals are being used (does this include stainless?) Anywhere else?
The blue threadlocker seems to claim some anti-seize properties - is this sufficient? Or should I use the actual stuff?
When I start on the engine next week
1. what do I put between gaskets and metal?
2. Do I coat pistons/ rings etc in anything?
TIA
JP
I pulled this from another web site and do give credit to the writer.
Building a No-Leak Engine, by Les Myer
Although I am a Sprite novice, I have built more engines than I can recall during my tenure as a professional mechanic for American automobiles in what seems like a previous life. Over the years, I developed many opinions as to how to successfully seal them against leaks. Recently, I performed a complete overhaul on the 1275cc in the 67 Sprite I acquired 6 months ago and applied my sealing techniques during the re-build. I am happy to say that after the first 400 miles, my engine has not leaked one drop of anything onto the white cardboard I have placed under the car when it is parked in my garage. I am not inferring that I am a Sprite expert in any way, but offer my opinions for your consideration. If I state something that is obviously stupid, let me know so I can learn.
Sprite engines are similar in basic design to American-made motors, except that they have no rear main oil seal. Instead, the rear-main cap / rear cap cover are machined to tight tolerances with the "sealing surface" (for lack of a better word) of the crankshaft. There are spiral grooves machined into the "sealing surface" to pull any escaping oil back into the crankcase. The fit of the cap and cover in relationship to the crankshaft is critical for oil control. If the block is line-bored, or if the cap/cover is allowed to scrape on the crank, this critical fit could easily be destroyed. There are kits available for installing a true rear main seal, - they are an option.
The 1098 and 1275cc engines have a PCV system that is supposed to maintain a vacuum on the crankcase. Air is drawn into the engine, by the PCV system, through a calibrated orifice in the oil filler cap. Maintaining such a vacuum certainly helps prevent oil from flowing through the tight tolerances of the rear main cap/cover. (The 948cc engine has a draft tube that creates a vaccum in the crankcase when the car passes through the air, but only vents the crankcase when the car is sitting still.)
The previous owner of my Sprite decided that a PCV valve was a "bad thing" and removed it as well as the hose leading from the oil separator mounted on the timing cover. Since the engine was in need of serious repair (2 exhaust valves leaking, >0.010 cylinder taper, flat cam lobes, etc), consequently there was considerable blow-by with no place to go except out the front cover, rear main, and every other seal on the engine. When pressure would build up, about a pint of oil at a time would blurb out the open orifice in the oil separator, all over the front of the engine and engine compartment. The moral to this story is that one should expect an engine to leak oil if 1) the crankcase ventilation system is not working properly and/or 2) excessive blow-by is present. On a 1098 or 1275cc engine, the idle RPMs should rise if the oil filler cap is removed (from my shop manual), thus indicating a vacuum on the crankcase was present before removal of the cap (assumed). If your car does not pass this test, you need to find out why and fix it or buy a big bag of oil dry and a case of oil to put in the trunk.
Installing the rear main cap cover correctly:
When overhauling an engine, it is not absolutely necessary to disturb the positioning of the rear main cap cover. I chose to remove mine due to concerns about destroying the cover-to-block gasket material during hot-tanking of the block. I left this cover off while checking bearing clearances with plastiguage. I then removed the crank and installed the rear cover/cover-to-block gasket in the following manner. After coating the gasket on both sides with Permatex Aviation Form-a-Gasket #3H I positioned the cover and tightened the three bolts firmly to squeeze out excess sealer before loosening them up a little so the cover could be moved around as much as the bolt holes would allow. I placed the crankshaft on the lubricated bearings and pushed the rear cover tightly against the crankshaft sealing surface before tightening the rear cover bolts to approximately 1/2 final torque. This exactly centers the rear cover, but leaves the rear cover too deep against the crank. (When the main cap is installed, the rear cover will be pushed away from the crankshaft sealing surface the proper distance). I then installed the rear main cap (with lubricated bearing) and torqued it to specifications before tightening the rear cover bolts to final torque. The crankshaft should spin freely without any rubbing on the rear cover. If not, the adjustment sequence will have to be repeated. After removing the rear main cap again and cleaning the cap mating surfaces with carburetor cleaner on a rag, I coated part of the rear main surface on the block from the "oil sealing surface" on the crank out to the edge of where the rear main cap would fit with Form-a-Gasket #3H, being careful not to use too much. All main caps were then installed and torqued to specifications.
Installing the rest of the gaskets except for the head and intake/exhaust gaskets:
I meticulously cleaned all sealing surfaces with carbuetor cleaner and a rag and inspected the bolt holes in the timing cover and oil pan for distortion from over-tightening, using a carpenter's square as a straight-edge. If a bolt hole was found to be pulled to far in, I put a big punch in the bolt hole and knocked the distortion back. Gaskets were coated on both sides with Form-a-Gasket #3H before installation. The front and rear oil pan corks were positioned in the oil pan and cut off 3/8" above the pan surface to ensure compression and a tight fit. The oil pan side gaskets were placed in position on the block and their ends as well as the end-seal sealing surfaces on the block were liberally dabbed with additional Form-a-Gasket. The end-seal guides in the pan were coated with Form-a-Gasket, the end seals were installed in the pan, the end-seals were coated again, and the pan was installed with a new bolt/washer kit. I did have to clean up a lot of squeezed-out sealer with a rag and rubbing alcohol. The rest of the gaskets were simply coated on both sides and installed, except for the intake/exhaust gaskets and the head gasket on which no sealer was used. I did use an accurate 10-75 ft/lb torque wrench on all bolts and re-torqued them after several days had passed.
Timing Cover Seal and Frost Plugs:
I installed the timing cover seal after wiping a coat of Blue Permatex RTV on the outer edge of the seal and also in the timing cover where the seal goes. Frost plugs were installed in a likewise manner.
Head Gasket:
The first head gasket I installed leaked bubbles of compression gasses out the threads of one head stud nut, while cranking the engine (without ever starting it). This gasket was obviously a bargain-basement item that came with the VB head kit as it had no markings as to what was "up" or "front". I may have installed it upside down but it should have sealed on the newly machined block and head surfaces, at least during cranking. After removing the head and gasket, nothing apparent could be found. I went in search of a quality head gasket and found out I could special order a head gasket from Fel-Pro through my local parts store. It cost more than the whole head set from VB but this gasket is a composition type gasket that comes pre-printed with special sealer on both sides and even has copper rings for the water passages - very impressive. I bought new grade 8 washers and small block Chevy rod nuts to fasten the head down and carefully wire-brushed all the head stud threads until the nuts could be literally spun down by brushing your hand against them. When going back together, I oiled the new nuts/washers and torqued the head down in 10 ft/lb increments, using the appropriate sequence.
Addendum............
""""""I am hoping to finish my caliper rebuild tonight. I was just at Canadian Tire & bought Permatex Ultra Disc Brake Caliper Lube. Is this the right stuff? """"""""
IF this is a brown grease about the consistency of chassis grease this product is meant for EXTERNAL to the caliper use such as pad/shoe sliding contacts and anchor pins.....stuff outside the calipe but inside the drum or moving pad parts.
For internal use the assembly lube is a petroleum jelly clear look and consistency. It comes in a very small tube and is expensive. AP, Alcon and others package this assy lube...BUT...it is not compatible with synthetic brake fluid (USA DOT 5). You should use a small amount of DOT 5 on a clean finger to lube the piston seals and other internal parts.
""""2. Do I coat pistons/ rings etc in anything?:""""
A LIGHT coat of oil in the bores and the piston skirts.
Six or so drops on each ring and rotate the rings to distribute the oil over the ring lands. Do not get any oil on the piston TOP. Dunking the rod and piston assy in a bucket of oil is an old wives tale.
Permatex Update
Just got off the phone with Permatex. They tell me the Disc Lube is compatible with with DOT 5 brake fluid (I presume because both are synthetic)
BTW at their website https://www.permatex.com there's a little video on properly using threadlocker. Another cold winter diversion.
BTW I just love this board - thanks all!
JP
