However, a TR6 that almost won't run, or will not exceed 55 mph is not normal, even if not driven regularly.
Dale, do I recall that you have a Pertronix ignition? If so, you might want to consider going back to the points & condenser , at least until this is ironed out.
If you don't have the Pertronix, then the symptoms you describe could be a faulty condenser,
I occasionally hear rumors that the relative humidity can get pretty high in Puerto Rico. Your engine ran lousey shortly after start-up,while things were cold, IIRC. Then when you pushed it hard and, presumably, it had run longer, things seemed to clear up. Next time that happens, or before your next ride (starting from cold), pop the distributor cap and check the inside of the cap and whatever else you can see amongst the dizzy components for condensation. Moisture might just be screwing things up until the heat dries it out.
Good luck.
Tom
