Still working through cooling system issues.
I have installed a 16 inch electric fan, I don't think it's that likely to fail and I want all the air flow I can get when at idle or in stop and go traffic. That's what I want, I will take the additional possible failure mode.
I have purchased a 160 degree thermostat.
My plan is to try both. While they are installed I want to measure the top and bottom of the radiator with the IR thermometer and see how well the radiator is cooling.
We are suppose to have some 70 degree days coming up so I will be trying this tonight or tomorrow.
Then be prepared to replace the radiator. I can't see how if it's clean and the fins are attached well to the tubes how these fall off in cooling efficiency? I suppose the join between the fins and the water tubes could become thermally blocked due to corrosion?
Anyway while doing some research, I was looking for what temperature range does the engine operate best at. The general info for this seems to be 200 degrees F and I saw a specific TR website that recommends 185 degrees F for TR6's.
Fairly close, based on this information, normal gauge operation should usually be between the first mark (~180 deg F) and the middle mark (~205 deg F) and rarely go above the middle mark.
Does this seem correct?
