desirable head?
darrenb
ok, done some more digging in the piles of parts, and there are two visuably useable blocks, but only one head, one block is an 18v, whilst the other one is a mystery, i guess i can pull the pan , but i am thinking it as a 3 main block, reason i am thinking this is the head thats on it, there are no air injection ports, and there is no provision for a water operated choke, ie no little outlet on back of head, is this head desireable? should i keep it with teh 3 main block? perhaps put it on the car, or rebuild the spare 18v engine and put older head? or am i lookign at fitment issues? what will i have to do to it to run unleaded, etc, or shoudl i just get rid of it, and make more room for other stuff in the garage like my jag??? lol
thanks in advance
DArren
May be a 3 or 5 main older engine. Either way it'd be closer to 100 HP stock than an 18V.
...just my take.
[ QUOTE ]
[/ QUOTE ]
That could be off either a 3- or 5-main engine....do you have the engine number? or at least know what the 'engine clock' says?
Clock says Tick Tick. Sorry bad joke. Its the Ky Bourbon Christmas cookies again. /ubbthreads/images/graemlins/devilgrin.gif
engine number plate has been removed, head says 67 if i remove valve cover, and i see a 65 on the block, not sure if that means anything though
Should be a kind of clock face thing cast in the side of the block that will tell you what date and year it was made.
It's got a pointer on it with a slot screw head inna middle.
Looks like this with different numbers. Below and behind the dizzy.
